Data Transfer Query
mcsheepie
Data Transfer Query
You have exceeded your allowance. Your usage has been extended by 8GB - charged at £7.20 on your next bill (£1.80 per 2GB).
Right, i stupidly went over my 8GB usage with 1 day left for the month. I thought i would go in and set a transfer usage to make sure i don't go over the 10GB mark tonight. And, now i'm confused, i added the basic £14.99 to the £7.20 and got £22.19. I set my usage to this and the thing says i have 9.1GB usage included for that money, how does that work out? Shouldn't it say 10GB?
The_10th
Data Transfer Query
Have you used 800MB though already?
Mand
Re: Data Transfer Query
I've just had a look at your account, and everything seems fine. It shows as having 10GB included.
Where are you seeing the 9.1GB message?
mcsheepie
I went into the data transfer thing, made it £22.19, said change and the next page said this
Amount: £ 22.19
For your information, your chosen amount allows you to use up to 9GB this month.
mcsheepie
Data Transfer Query
You have exceeded your allowance. Your usage has been extended by 10GB - charged at £9.00 on your next bill (£1.80 per 2GB).
Now my VMBU says this! Now i'm pretty certain that £23.99 (14.99 + 9.00) is more than £22.19. Does the transfer watch work?
mcsheepie
Data Transfer Query
And it gets stranger, i have been sent an email saying i'm being billed for £22.19 (i.e 8GB extra, so even though i went over the limit in terms of usage i'm not being charged), and my VMBU history for last month does say that i used 10.37GB.
What's going on?
