DSL Max Connection table?
Does anyone have the table where it shows a list of sync speeds and the DSL Max connection you would get for that sync?
Cheers
Try this but be aware it is only a rough guideline and may not be indicative of the speed you will end up receiving.
No its not that one, as I already have Max DSL.
The table I am referring to is a list of sync speeds and what speed BT's BRAS will set your profile at, for example, if I have a sync speed of 4128kbps the max I will be set to is 3.5 mbps.
In that case you'll want this.
Thnx for that Smiley
Cheers
