DOMAIN TRANSFER
DOMAIN TRANSFER
Hello support: 3 weeks ago I changed the IPS tags of my domain ( www.4eurocars.co.uk ) from your "FORCE9" to "FASTHOSTS" for a transfer out request. There was no fee due as I have held it past the minimum time. The box next to the domains said: "Awaiting Authorisation" (or words to that effect). It should take 48 hours but I've just checked and it's still the same making it impossible to move. Can you please advise what the delay is? Thanks,
1 REPLY
RE: DOMAIN TRANSFER
Your account is actually 11 months old and as such you will owe the registration fee for the domain if you remove it before the account reaches its 12 months period.
If you still wish to remove the domain name now, then raise a contact via the contact us system. If, you wish to wait a few more weeks, then raise the request later.
Kind Regards
Kevin
| Kevin Revill ............... Unmetered & ADSL solutions
| Technical Support ................. for Home & Business
| PlusNet Technologies Ltd. ....... @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
