DNS
DNS
Is anyone having trouble accessing websites tonight?
I can't get into BBC, BT, ADSLguide Samknows and I suspect more.
I have a feeling it's the DNS could someone give me the beeb's IP so I can try that?
DNS
Scrap that, it was my firewall disable it and works fine! Could someone give me the beeb's IP anyway for future reference!
Edit, looks like it wasn't the firewall! I dissconnected and recconected using the big button on the binatone modem page and it seems to be working now - but why would this happen in the first place?
DNS
I'm getting timeouts on roughly everything including BBC which is normally ultra reliable. Not using a firewall either Smiley
DNS
It's weird firefox doesn't give me "The operation timed out when trying to contact www.blahblahblah.com"
I got "www.website.com could not be found"
Ben, Dave, Jon, Stew; are there any problems tonight?
DNS
It's weird firefox doesn't give me "The operation timed out when trying to contact www.blahblahblah.com" I got "www.website.com could not be found"
Both are timeouts anyways, given that theres an Email problems thread on the forum thats just been created, I'd say Plusnuts have a big problem. Then again what else is new Smiley
DNS
My connection seems to be working again now but It's got me wondering what's going on as my connection is normaly pretty rock solid - if not that speedy :-)
DNS
Phil (acarr in a previous incarnation :razz: ) to the rescue:
We are currently investigating timeouts on some of our gateways. This will cause intermitant connectivity problems.
Our network engineers are investigating and further updates will be made when available.
Kind regards,
Phil Richardson
Customer Support
DNS
Lots of problems tonight, my router has just been re connected and it was issued with the wrong ip address and dns servers
System Status
System Uptime: 3503:44:10
LAN Status Primary DNS 194.74.65.98 Secondary DNS 193.113.211.125
IP Address TX Packets RX Packets
192.168.1.1 231139738 134367478
WAN Status GW IP Addr 217.32.89.137
Mode IP Address TX Packets TX Rate RX Packets RX Rate Up Time
PPPoA 81.152.132.251 114 95 17 1 0:01:07
ADSL Information (ADSL Firmware Version : 41e2be2c)
ATM Statistics TX Blocks RX Blocks Corrected Blocks Uncorrected Blocks
1489552114 1489551907 0 16353
ADSL Status Mode State Up Speed Down Speed SNR Margin Loop Att.
G.DMT SHOWTIME 288000 2272000 34.0 15.0
i cant ping the bbc either.
___oDiN__
DNS
yeah my connection crapped itself too
Sad
DNS
:lol: I know I shouldn't laugh but that is such an apt description!
DNS
me on dial up at present for last half hour,adsl ysnc problems,the wrong dns servers given,had to specify manually.
DNS
If you're having sync problems that is a different problem work through:
http://usertools.plus.net/tutorials/id/10
and
http://usertools.plus.net/tutorials/id/13
DNS
Same here,constant timeouts & disconnections, even on portal pages.
IE & Firefox are both the same.
Sad
DNS
Something definitely went t*ts up, though it's back on now.
I lost routing to 2 other PN connections I'm permanently connected to by VPN.
DNS was not responding.
A re-connect gave me the wrong IP and DNS twice,then OK.
Seems to have dealt with quickly though.(Finds some wood to touch!)
DNS
Yup, seems to have suddenly improved.
I can connect to external websites now, but some portal pages are still timing out(eg, view my usage).
