DNS servers buggering about again?
I registered a domain the other day, now its fully resolved blah blah.
It worked for about half a day, straight to my site, perfect.
Then, it resorts back to the registrars site, oook, check again, yup, reggers site.
Asked a bunch of people I know using different ISP`s arround the world, and the domain works fine for them?!
Are the DNS servers throwing a tantrum again or something? :roll:
The domain is deltaoutpost.com, just so you know.
LiamM
That site is resolving without problems for me.
Have you tried clearing your cache?
[EDIT - I am rather stupid, have just realised that I am indeed not at home on my PN connection. I'm at my girlfriends, and she is on Demon. Working fine on Demon then, perhaps this proves your point!]
[EDIT 2 - Just checked at home (don't ya love Remote Desktop) and resolves fine on my PN Connection at home.]
Plusnet Staff
Plusnet Staff
From here it's pointing to a UK Reg page.
Have you changed the nameservers on the domain? As a whois is showing them as
NS1.HU-JULIET.COM 67.15.58.95
NS2.HU-JULIET.COM 67.15.58.96
but on a dig on our name servers I'm seeing
deltaoutpost.com. 67811 IN NS ns2.fast-hosts.org.
deltaoutpost.com. 67811 IN NS ns1.fast-hosts.org.
Which should be correct and when was it last changed?
These two are correct.
The nameservers were changed on the 12th.
During /most/ of yesterday the domain was working fine, but since late evening and till now, its back to the registrars site.
LiamM
Dave, I can access the site fine from both my home Plusnet 2Mb Connection and my Demon 512k Connection at my girlfriends house.
Plusnet DNS Servers I am using are :
212.159.6.10
212.159.6.9
Cheers,
Liam
Plusnet Staff
Plusnet Staff
Actually, looking at each DNS servers, 3 of them have the correct record cached, but 212.15.13.49 has the old record. I think it's just going to be a case of waiting for the TTL to expire and this will update to the correct record.
[dtomlinson@csctools dtomlinson]$ dig @212.159.13.49 deltaoutpost.com
; <<>> DiG 9.2.2-P3 <<>> @212.159.13.49 deltaoutpost.com
;; global options: printcmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 3453
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 2, ADDITIONAL: 2
;; QUESTION SECTION:
;deltaoutpost.com. IN A
;; ANSWER SECTION:
deltaoutpost.com. 20227 IN A 213.171.192.236
;; AUTHORITY SECTION:
deltaoutpost.com. 66711 IN NS ns1.fast-hosts.org.
deltaoutpost.com. 66711 IN NS ns2.fast-hosts.org.
;; ADDITIONAL SECTION:
ns1.fast-hosts.org. 817 IN A 213.171.192.236
ns2.fast-hosts.org. 817 IN A 213.171.192.237
;; Query time: 9 msec
;; SERVER: 212.159.13.49#53(212.159.13.49)
;; WHEN: Mon Feb 14 17:12:40 2005
;; MSG SIZE rcvd: 132
Oh well thats a shame, rather annoying to see it working one day then not the next.
Thanks anyway. Smiley
Plusnet Staff
Plusnet Staff
I suspect yesterday it was doing the look up on one of the other 3 DNS servers, but today is using the one that has the old record cached.
I stoped using PN's own dns servers a while back and just have my own dns server runnin. Definatly worth setting up
LiamM
How do you do that then? Thats interesting.
I've always found Plusnet DNS servers to be pretty reliable. They did go through a sticky period a few months ago I remember but PN kindly recommisioned some new kit IIRC.
If you're still having problems, manually set your DNS servers to the ones I posted above and then reconnect. You should then be able to see your site without problems.
