DNS problems. AGAIN
DNS problems. AGAIN
Ok what is going on!
DNS Is seriously fucked to say it nicely!!
Doesn't seem like plus are even fixing anything!? its not on the status page!
main issues: cannot resolve domains. also issues while connecting to ADSL reported DNS failed.
Anyone having this problem?
Liam
DNS problems. AGAIN
It's not on Service Status because it should be working fine... We've not had any other reports of it... anyone else having a similar problem?
The graphing, here http://www.plus.net/support/network_performance/dns_response_times.shtml?supporta=networkpdns ) seems to show responses fine.
Moderators note by John (johnessex) Spaces inserted into the brackets to make the URL work correctly
DNS problems. AGAIN
You graph is of major sites.
plus my dns issues are all subdomains!
example
www.genietexter.co.uk (addon domain of www.reborn-network.co.uk)
there for subdomain.
aswell as my.ebay!!!
check yourself.
Liam
DNS problems. AGAIN
Those Domains, and http://my.ebay.co.uk resolve fine.
DNS problems. AGAIN
Server not found
Firefox can't find the server at signin.ebay.co.uk.
* Check the address for typing errors such as
ww.example.com instead of
www.example.com
* If you are unable to load any pages, check your computer's network
connection.
* If your computer or network is protected by a firewall or proxy, make sure
that Firefox is permitted to access the Web.
Liam
DNS problems. AGAIN
Have you tried rebooting your router or reconnecting your modem?
Which DNS servers are you using / assigned?
DNS problems. AGAIN
rebooted router 2 times today. although ebay now seems to be working...
Not sure of DNS as router gets the ip's automatically but doesn't list them..
according to my members area (plusnet)
Primary DNS Server 212.159.13.49
Secondary DNS Server 212.159.13.50
Optional tertiary DNS server 212.159.6.9
Liam
DNS problems. AGAIN
They are our DNS servers, but you need to check what servers your router, and your connection - are actually using.
You can typically do this in the Control Panel of the router, and the "Properties" option of the Network Connection in Windows.
DNS problems. AGAIN
Cant view via my router. at least i cant find it and ive looked everywhere.
Also, my DNS in network connections is set to the router (as normal)
btw my router is: NetGear DG814
craign
DNS problems. AGAIN
C:\Documents and Settings\Craig>nslookup www.hp.com
Server: pth-cdns01.plus.net
Address: 212.159.13.49
*** pth-cdns01.plus.net can't find www.hp.com: Server failed
and 30 secs later
Non-authoritative answer:
Addresses: 192.6.165.40, 15.200.30.24
Aliases: www.hp.com
craign
DNS problems. AGAIN
and
[5 times]
C:\Documents and Settings\Craig>nslookup www.hp.co.uk
*** pth-cdns01.plus.net can't find www.hp.co.uk: Server failed
then
Aliases: www.hp.co.uk, whp-ccjump.extweb.hp.com
IanD
DNS problems. AGAIN
Can't access www.trafficscotland.org, www.autosport.com, uk.weather.com, www.eastrenfrewshire.gov.uk amongst many that are not working.
www.bbc.co.uk is OK as is www.plus.net
Exactly the same symptoms as the previous DNS problem when various sites would load, whilst others failed.
Anyone else have the same problems we are having?
IanD
DNS problems. AGAIN
www.hp.co.uk not working for me either
DNS problems. AGAIN
All night tonight we have been getting "page cannot be displayed" on IE.
The router has had a hard reset earlier and it seems to have made it worse.
Would this also affect as to why we couldnt access our router settings earlier? We kept getting IE searching the 192.168 etc on the default search instead of attempting to make a connection.
DNS problems. AGAIN
yes same problem here too.
