DNS problem/timeouts
I keep getting DNS timeouts every new and then. I have restarted my router (834G) and also cleared DNS cache. But this will solve the problem for a few days/weeks, it then re-occurs. Happens on nearly every website (google, Ebay, Amazon etc.) except Plusnet site.
Anyone know a solution?
1 REPLY
Fixes: 8
I've suspected for some time that there is a memory leak or similar bug on the 834 as I see a similar thing - disconnect/reconnect makes no difference whereas power off/reboot the router does.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
