DNS Problem
DNS Problem
This has occured on a regular basis for the past week or so...
2/6/2006 14:41:14> Lost contact with DNS servers
2/6/2006 6:57:16> Regained contact with DNS servers
2/6/2006 6:56:37> Lost contact with DNS servers
2/6/2006 6:56:25> Regained contact with DNS servers
2/6/2006 6:56:22> Lost contact with DNS servers
2/6/2006 5:12:46> Regained contact with DNS servers
2/6/2006 5:12:44> Lost contact with DNS servers
(Please ignore the time, most of the time my modem thinks its 1970).
This particular event happened at approximately 11pm and then continued as demonstrated above.
Anyone else having similar problems?
DNS Problem
DNS is SHIT, i'm currently on here looking for the post where the guy gave details of the BT DNS servers.
DNS Problem
Found it.
http://portal.plus.net/central/forums/viewtopic.php?t=38852&highlight=dns
Wacked the BT servers in as the DNS servers and it's instantly better.
Explain that plus.net. Maybe it's contention, maybe it's my exchange, maybe it's my configs or maybe, just maybe you have a problem that you never ever fix.
rslsys
DNS Problem
Didn't think that I generally had a DNS problem.
Just tried the BT DNS servers in preference to +net's.
It is like someone has just turbo-charged my browser.
Can't believe the difference it has made to browsing speed.
DNS Problem
I've just done the same and it has really improved things...
Amazed by the difference
Nice one bt Smiley
DNS Problem
how do u do it?Huh
rslsys
DNS Problem
In my case I just ran the wizard on our Small Business Server 2003 to alter the DNS servers that it refers to. Depending on how you connect to the Internet either change the settings in your router (if you connect that way). Or open up your Network Connections, select the network connector you use to connect to the Internet, select properties then Internet Protocol (TCP/IP). Enter the BT DNS servers in the "Use the following DNS Servers" fields. This assumes you are running Windows XP. I'm sure other users will post if you are running anything different.
