DNS Issues
DNS Issues
It's now been 3 days since the last service status on this issue and I'm still having sporadic web browsing and e-mail problems due to this. I'd like to know when this is likely to be rectified....
ChrisC
DNS Issues
Hi, it is even worse today, almost unusable. I'm not sure how much more I want to put up with this b4 I seriously consider going elswhere...
ChrisC
DNS Issues
Mine's pretty bad too... I can hardly access any of the sites I normally go on... =/
DNS Issues
Hi and thx for your reply..
I'm also getting spam, some sexually related, that I wasn't getting before, some of my pop3 accounts are only working sporadically. As a IT Technician I need to know whats going on with the DNS issue, what steps +net they are taking to reach a solution. Then I can make a decision as to whether I can continue to depend upon +net as a service provider when I'm at home....
ChrisC
DNS Issues
have you tried using alternate DNS servers?
208.67.222.222
208.67.220.220 are a good start.
these are from www.opendns.com .
regards,
DNS Issues
My DNS servers were fine today?
DNS Issues
Hi, I can change them , however they have worked fine in the past without any such entries. After all it is +net who are stating there are issues such as mine...
Chris
DNS Issues
Hi Chris,
Indeed I see your point and mentality. However While I would love to depend on just 1 dedictaed set of DNS servers, past experience has proven to me that doing so is foolish ( unless your own which are blocked to the public ).
Any server can go down, and any server can encounter difficulties. This does not eradicate Plusnets responsibility I know, but its these possibilities that give reason to make sure your covered.
I use a multitude of DNS servers, and thats me being overly safe.
Regards,
DNS Issues
Hi, well somthing isn't right because I have once again received two fairly obscene e-mails today. I thought +net was supposed to filter these out?
ChrisC
