DNS Errors
DNS Errors
I am currently getting random DNS errors for my domain. Checking with DNSSTUFF to look up my A record which I have manually set, sometimes shows the right IP but often (if you refresh the page) shows the wrong IP Address. http://www.dnsstuff.com/tools/lookup.ch?name=www.borpin.co.uk&type=A
Anyone else experienced this.
My domain settings on the portal are.....
Left field Type Pri Right field
sbfaq.borpin.co.uk. a 65.98.41.242
test.borpin.co.uk. a 65.98.41.242
www.sbfaq.borpin.co.uk. a 65.98.41.242
www cname borpin.co.uk.
www.test cname borpin.co.uk.
Anyone spot a problem with this? Is the order important?
Cheers
DNS Errors
Well, using dig, querying ns2.force9.net seems to always return the correct address, but ns1 seems to sometimes return homepages.plus.net, so I'd say it's a problem at plusnet's end and you should raise a ticket over the issue.
DNS Errors
Thanks for that. I thought I was going mad. I had raised a ticket but nothing yet. To keep things going I created an A record for www.borpin.co.uk so I can get to the new site. http://borpin.co.uk still sometimes returns me back to plusnet homepages.
It does now look like it is just NS1 that is the problem.
Cheers
Try...
Just add a another A record ...it will cause the serial of domain up be updated and then both dns servers will be in sync.
so just make up a new A record ..
Then delete after NS are in sync.
Re: Try...
OK I have tried that. I was hoping that the problems last night were related and today it would be better but it isn't Sad
One odd thing though. When I have added other records they have gone to the bottom of the list. This new one went in at the top. Does the order of the entries matter?
Cheers
