DI 514 does work?
DI 514 does work?
I got a Thomson SpeedTouch 510v6 gateway and DI-514 wirelss router. But when I used only the Thomson Speed tourhc 510 v6 gateway, it is working well. However, when I connected the modem with the router according to the manual of DI 514, I can not get access to internet anymore. I also go to the dlink support website and reset all the stuff under the guidance,still not working. Comments are greatly appreciated!
Best regards,
zibin
1 REPLY
aedwards
DI 514 does work?
Possibly the machine isn't getting an IP address for some reason.
This assumes it's a Windows 2000 or better PC...
Check that the DHCP server is switched on in the wireless router, and in Windows control panel that the machine isn't set up with a fixed IP address.
If you start a command prompt and type IPCONFIG, it should tell you it has an IP address of 192.168.something (or 10.something), with a similar default gateway.
Do you have any other machines on the network? Can the machine see those other machines?
Alan.
