Custom Error messages...
Can I/How do I make my own custom error messages for errors such as 404, 403, 401 etc etc...
Cheers
Will
benoh
RE: Custom Error messages...
> Cheers
> Will
Hi Will,
You need to use a .htaccess file to redirect to the file you want.
have a search on www.apache.org for the correct directrives, I believe its something like
ErrorDocument 404 /full/path/to/file.html
The full patch to files is as follows
/share/isp/plusnet/www/XX/username/htdocs
where XX= first 2 letters of your username.
Ben O'Hara
Network Support Analyst
PlusNET Technologies.
Thanks Ben,
By the way I gave up on that crontab I only ever managed to get it to work once and then nothing... but thanks for the help on that as well
Cheers
Will
I've been thinking of creating my own 404s one day. i shall have to check this myself.
Chris
| Chris Rugen ................................ Unmetered & ADSL solutions
| Customer Support................................... for Home & Business
| PlusNet Technologies Ltd ........................... http://www.plus.net
+ ---------- My Referrals - It pays to recommend PlusNet ---------------
Chris,
To save you some time...
put simply in the root directory for the web site (I presume actually in htdocs but could someone check) put a .htaccess file and in that have the lines
ErrorDocument 400 "This will display this text on screen
ErrorDocument 401 /path/to/file/file.htm
ErrorDocument 402 http://host.name.com/file/file.htm
ErrorDocument 403 "etc etc etc
ErrorDocument 404 "and so on for the rest of the errors
and the error codes are!
400 = bad request
401 = Authorization required
403 = Forbiden
404 = Page not found (aka 4 ohhh 4)
500 = Script failure (aka Server naffed up)
Cheers
Will
Thanks for the information!
I'll try this in a few weeks.
Chris
Although you'll probably read this... heres something good for the dreaded 4 ohhh 4...
http://portal.plus.net/central.html?action=new_forums&forum_action=display_topic&topic_id=1262&displ...
Cheers
Will
