Current Situation with connectivity?
What is happening with connectivity at the moment?
Updates simply say we are monitoring the situation I have been able to use my connection and although seems a little slower than normal it does seem ok. Are there still problems with your link provider?
Would just like to know if its going to stay ok or go off like over the weekend
1 REPLY
RE: Current Situation with connectivity?
Our intention is to carry out further work on our DSL platform in the next few days. Unfortunately, I can't be more specific so I can't offer a time when the work will indeed be carried out.
When the work is carried out our aim is to provide as little downtime as possible. We will of course keep you all updated with news and updates.
Best Regards,
Dave Watson.
| David Watson. Unmetered & ADSL solutions
| Technical Support. for Home & Business
| PlusNet Technologies Ltd. @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----- +
