Creating mailboxes on domains other than default domain
Does anyone know of a way to create mailboxes for a domain I just transferred in from another ISP? I've been to Email Settings > Configure Mailboxes, but just get the default mailbox showing.
Regards,
James
Mailboxes are configured globally accross all your hosted domains from this option.
So if you create the mailbox user@username.plus.com, then you create the mailbox ser for your domains as well.
OK, so if my domain name is www.blah.co.uk, then my "username" is "blah" and so I create the mailbox user@blah.plus.com then that will create an account for user@blah.co.uk? Is that correct?
James
Yes.
Any mail for anyone@blah.co.uk goes to the same mailbox name under @blah.plus.com. If no mailbox exists under blah.plus.com it goes into your default mailbox.
PlusNet does not support having separate mailboxes for domains linked to your account. mailbox@domain1.com & mailbox@domain2.com all go into mailbox@blah.plus.com
See the doamins help page here.
