Couldn't Connect
michaelscott
Couldn't Connect
at about 1140 this morning my connection died and I was unable to connect again until 1405. Did anybody else experience this? Does anybody know why?
lowry
Couldn't Connect
There does not appear to be anything on service status that would reflect this problem and I haven't seen any posts on here or on ADSLGuide concerning this so it may just be an issue local to you. It may have been the result of some work being carried out by BT today between your line and the exchange, or at the exchange.
Was your voice service OK at the time?
matt Wink
Couldn't Connect
Have you checked your exchange status? disconnections to happen from time to time. Are you back on now, with no problems?
Aaron
Plusnet Staff
Plusnet Staff
Couldn't Connect
There's no MSO's showing in your area so it's difficult to say what the cause was. Let us know if it happens again.
michaelscott
Couldn't Connect
Somebody else in my area had the same problem - clearly an exchange issue
Couldn't Connect
Sad
Dear all,
I am hoping you can help me. I have signed up to Connect Lite, and according to my account my direct debit is sorted, however when I try and change the dial-up number and dial up, it will get as far as authenticating user name and password then log off.
Please help!
Ally
Plusnet Staff
Plusnet Staff
Couldn't Connect
Hi Ally,
Try it again now, I've refreshed your account details.
Couldn't Connect
That's great Dave,
Thanks very much!
Ally
