Contract changes?
The_10th
Contract changes?
If a user wishes to change PAYG useage in a month how many times can it be done in the month?
Also if the usage is changed can products be changed too in the same month?
Plusnet Staff
Plusnet Staff
Fixes: 159
Contract changes?
You can add usage on for 75p per GB in advance of when you need it, you can add as many as you want in one go but can only do this once every 30 days.
If you use more than the usage you have specified you can then add more for £1 per GB.
Products can only be changed once every 30 days.
 Chris Parr
 Plusnet Staff
The_10th
Contract changes?
Thanks Chris but can you increase usage and in the 30days change products?
Plusnet Staff
Plusnet Staff
Contract changes?
I think it would depend on the exact circumstances, you'd be able to upgrade but not downgrade, so could increase PAYG bandwidth and then upgrade to a higher or same cost BBYW product for example.
The_10th
Contract changes?
So changing from PAYG 10GB to Option 3 will cost me only within the 30 days. Outside of 30 days is free?
Plusnet Staff
Plusnet Staff
Contract changes?
There wouldn't be a downgrade fee to change account type if that's what you mean either within or after the 30 days, but if you make 2 changes, i.e. increase to PAYG 10GB then you would have to wait 30 days before downgrading.
The_10th
Contract changes?
Thanks, I changed to Option 3 and managed to do it early thanks to the very helpful PN Helpdesk staff Dave Wink
Hope the move is a good 'un :? Never been 'coya'd before.
