Constant disconnections since upgrade
My connection suddenly disconnects randomly every 10-15 mins, sometimes it will last an hour or two then start again but it's rather annoying, anyone else having this problem/any suggestions on how to fix it? It disconnects and the little green arrows start flashing a bit then go back to green and I can reconnect
deepfatfrier
How far are you from your telephone exchange? (Probably in your nearest town)
If you're quite a way (2 miles or more) there's a chance you could be outside the limits for your connection speed. If this is the case, just ask to be moved down to a slower speed, and this should fix it. Smiley
If you're close to your exchange, I have no idea :?
Good luck, either way.
Humm, i'll have to find that out, it seems to be fine now though, i;ve been conencted for 4 hours without a problem :?
I have had a big problem with disconnects today (so maybe the new policy won't be such a problem after all :lol: ). The problem I have is that all types of "atmospherics" affect my connection due to how close I am to the limits of being able to receive my current speed. Normally the disconnections aren't a problem, but with the unsettled weather here in Leeds, the last few days have been trying.
Regards
Mark
Oh joy the problems are back Cry
It wouldn't be such a problem if I was just looking at sites and such but when you're depended on to lead teams in games and things it's quite annoying :shock:
Plusnet Staff
Plusnet Staff
Take a look through the following
http://usertools.force9.net/tutorials/id/10
and
http://usertools.force9.net/tutorials/id/13
and see if anything there helps.
If not, raise a ticket via Contact Us, there's a specific path for intermittant connections, answer the 16 questions and we'll run some remote testing.
• Report a problem on a BT Installed ADSL account (I accept an admin charge may apply)
Please Note:
We would urge customers to take care when answering questions in the troubleshooter. If the fault is found to be due to your equipment or configuration then an administration charge of £54.05 (£46+VAT) may be issued.
Hmm, don't really want to pay £54.05 if there's a problem with the equipment...When I was on 576k everything worked fine so I guess it's fine and a problem with the new speed? :shock:
