Connection speed
Connection speed
Sad is anyone having dificulty with the speed of there connection. over the last week mine as dropped from constant 1KB to just 340 kbps at all timesthis is a third of the spped i have been getting afer paying extra for a upgrade Sad
Plusnet Staff
Plusnet Staff
Connection speed
What speeds do the BT speedtester show?
http://usertools.plus.net/tutorials/id/27
Also have you checked the status of your exchange to see if there are any known problems?
http://usertools.plus.net/exchanges/
Connection speed
these are the results of the BT Speed Test
Test 1 at 19:30 26/06/05
320 kilo bits per second (Kbps)
Test 2 at 05:58 27/06/05
329 kilo bits per second (Kbps),
Test 3 at 06:30 27/06/05
339 kilo bits per second (Kbps),
Test 4 at 07:00 27/06/05
364 kilo bits per second (Kbps),
Test 5 at 02:50 28/06/05
356 kilo bits per second (Kbps),
Test 6 at 2:56 28/06/05
340 kilo bits per second (Kbps),
Test 7 at 03:31 28/06/05
Test 8 at 03:38 28/06/05
348 kilo bits per second (Kbps),
I noted that they did a upgrade to the exchange on the 21st June 2005
and after thisi i noticed a downgrade in speed, Plusnet say that this is within BTs permitted range for a 1Kb connection and have not contacted BT to resolve this speed problem.
Connection speed
If that's on a 1KB connection you are at 300x your max. Do you mean 1MB?
Connection speed
Sorry yes I mean 1Mb
