Connection problems
Connection problems
Wasn't sure if anyone else had a similar problem - so I thought I'd post something publicly to check...
I've been on plusnet for almost a month now, and every time I disconnect, I have to reinstall the modem (a zexel model - under control panel - adsl, choose to reinstall the connection), otherwise it just will not connect.
Funnily enough - it always works straight away after the 'reinstall'.
Anyone else have a similar problem? Any idea how it can be fixed - if so, I'd appreciate hearing it!
Thanks in advance
Sean
