Connection problem
Connection problem
Signed up for Lite service last evening. Just tried to connect for the first time and having dialled 15 times have given up and used another ISP 0845 number.
I know contention is 15:1, but is this typical?
If so I guess I'll start looking again!
Mike
RE: Connection problem
> Mike
Seems like you are suffering from the same problems as me. You then have to use it during the day to make sure you get all the things you want done, then you get told off by plusnet for using the service too much !! . can't win !!
Nigel
> Mike
Hi Mike,
Please see my reply in the previous thread 'Too much Useage', this should hopefully address your points.
Kind Regards,
Rob
| Robert Kelly.....................Unmetered & ADSL solutions
| Technical Support...................for Home & Business
| PlusNet Technologies Ltd...........@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
