Connection dropping problems New DG834G Firmware out
Wheelie
Ok not sure if this will help with anyone like me who keeps losing there connection but there is a new firmware out Version 3.01.25
Modifications and Bug Fixes
Version 3.01.25
The ADSL driver was updated to improve ADSL2+ performance, improve power cutback operation, add support for Cabinet Mode, and fix various DSLAM interoperability issues.
The firewall was updated to resolve various issues and improve performance.
Fixed a problem with UPnP which prevented certain applications from adding port mapping via UPnP.
Added New Zealand to Wireless Country Settings pulldown menu.
Fixed a problem where certain time zones were not restored from config file.
Fixed a problem where a Gateway to Gateway VPN tunnel would fail if DMZ used.
Fixed a problem where a LAN service could not be accessed via WAN IP.
Fixed a problem where "NETGEAR *Security Alert*" emails could be sent from the router when only Scheduled Emails have been configured and no "Send E-Mail alerts immediately" boxes were checked.
ADSL loss of sync events now recorded in log.
Known Issues
The router GUI may not behave correctly in Mozilla Web browers
Link here chose your model
Lets hope it helps Wink
Re: Connection dropping problems New DG834G Firmware out
That should be useful for some Smiley
Wheelie
Yep thats what I was thinking lets hope that new feature works though Smiley
Good Call. Cool
Whose going to be the guinea pig then? Smiley I can't til I get home.
It's working well for me.
Wheelie
Its working fine here so far as well but only time will tell Smiley
Good stuff, I'll assume it's safe to flash again :shock: Smiley
Wheelie
Well I had a problem with it so just in case anyone else does I could'nt figure out why downloads from MS would just stop as soon as you started to download and this was the reason.
There are new features for Trend Micro Home Network Security and if you don't disable them you will have problems when trying to download via a website not sure if the same problem occurs if you go and register with Trend Micro though.
Anyone else seen this problem or is it just me?
mitchell20
Upgraded to new firmware here with no probs at all (as with every firmware version I've put on so far)
avalon
Anyone tried out this Trend Micro stuff yet. Does it work only with XP or with other OS's as well. From the Trend website it seems to be aimed at XP users.
I haven't tried it out yet coz I work on the if it ain't broke don't fix it principle and my little netgear box has been doing ok so far (famous last words). But I might be tempted if the new firmware included AV scanning & spyware detection on the router which seems to be what Trends promo suggests it does.
Wheelie
Yes I am not using it on my system but I have updated my neighbours router with it and gone through the registration procedure for them just waiting for the activation email to arrive from Trend
You can find the System Requirements Here
I will post more info once I have it all working for them Wink
mitchell20
No not using the Trend software here as I already use Norton Internet Security
Thanks for the heads up man. Got that link bookmarked and was going to check it last night, but just thought that they'd be no chance of an update anytime soon so I skipped it Smiley
/me flashes up
seems to be running fine no disconnects 2 day so far
