Connection Problems
Connection Problems
Every now and again I will have a problem where by I will loose all HTTP connectivity first of all I thought it was my Wirless or Router but I could still ping the router and also external websites\IP addresses. This would last for approx 30 mins and then all of a sudden it would work again. This has happened on both my desktop and laptop computers. It could happen 5 or 6 times in an evening and then not happen for a week or so or it could happen over a number of days.
Jon
Likely Cause?
Sounds like a DNS problem. If you reboot the modem it may pick up a different set of DNS servers (this used to happen to me a lot when I was with BT)
Re: Likely Cause?
is this the case?..... my modem/router is still as configured X years ago and has DNS servers specified. although i just noticed they no longer match the ones on the connection details section on the portal :roll:
should i be auto-detecting?? :shock:
Julie
Connection Problems
I do not have a router or any personal experience with them so someone more knowledgable should be able to tell you if it is better to set them to auto-detect.
However, for your information the four DNS servers are
212.159.13.49
212.159.13.50
212.159.6.9
212.159.6.10
sorry I could not be of more help,
