Connection Problem?
Connection Problem?
Since 2 days ago I have noticed strange things with my upload speed, it uploads a 30k for about 2mins then goes down to 0k then back up to 30k and keeps doing it? Also I am doing a ping from work and about every 10 pings I get request timed out?
Pinging deandodd.plus.com [212.159.108.127] with 32 bytes of data:
Reply from 212.159.108.127: bytes=32 time=91ms TTL=235
Reply from 212.159.108.127: bytes=32 time=180ms TTL=235
Request timed out.
Reply from 212.159.108.127: bytes=32 time=161ms TTL=235
Reply from 212.159.108.127: bytes=32 time=118ms TTL=235
Reply from 212.159.108.127: bytes=32 time=163ms TTL=235
Reply from 212.159.108.127: bytes=32 time=252ms TTL=235
Reply from 212.159.108.127: bytes=32 time=214ms TTL=235
Reply from 212.159.108.127: bytes=32 time=257ms TTL=235
Reply from 212.159.108.127: bytes=32 time=96ms TTL=235
Reply from 212.159.108.127: bytes=32 time=178ms TTL=235
Reply from 212.159.108.127: bytes=32 time=262ms TTL=235
Reply from 212.159.108.127: bytes=32 time=199ms TTL=235
Reply from 212.159.108.127: bytes=32 time=162ms TTL=235
Reply from 212.159.108.127: bytes=32 time=248ms TTL=235
Reply from 212.159.108.127: bytes=32 time=194ms TTL=235
Reply from 212.159.108.127: bytes=32 time=99ms TTL=235
Reply from 212.159.108.127: bytes=32 time=193ms TTL=235
Reply from 212.159.108.127: bytes=32 time=153ms TTL=235
Reply from 212.159.108.127: bytes=32 time=117ms TTL=235
Reply from 212.159.108.127: bytes=32 time=172ms TTL=235
Reply from 212.159.108.127: bytes=32 time=294ms TTL=235
Reply from 212.159.108.127: bytes=32 time=270ms TTL=235
Reply from 212.159.108.127: bytes=32 time=111ms TTL=235
Reply from 212.159.108.127: bytes=32 time=208ms TTL=235
Reply from 212.159.108.127: bytes=32 time=171ms TTL=235
Reply from 212.159.108.127: bytes=32 time=224ms TTL=235
Reply from 212.159.108.127: bytes=32 time=189ms TTL=235
Reply from 212.159.108.127: bytes=32 time=283ms TTL=235
Reply from 212.159.108.127: bytes=32 time=130ms TTL=235
Reply from 212.159.108.127: bytes=32 time=197ms TTL=235
Reply from 212.159.108.127: bytes=32 time=196ms TTL=235
Reply from 212.159.108.127: bytes=32 time=238ms TTL=235
Reply from 212.159.108.127: bytes=32 time=198ms TTL=235
Reply from 212.159.108.127: bytes=32 time=156ms TTL=235
Reply from 212.159.108.127: bytes=32 time=233ms TTL=235
Reply from 212.159.108.127: bytes=32 time=152ms TTL=235
Reply from 212.159.108.127: bytes=32 time=278ms TTL=235
Reply from 212.159.108.127: bytes=32 time=71ms TTL=235
Reply from 212.159.108.127: bytes=32 time=470ms TTL=235
Reply from 212.159.108.127: bytes=32 time=155ms TTL=235
Reply from 212.159.108.127: bytes=32 time=204ms TTL=235
Reply from 212.159.108.127: bytes=32 time=167ms TTL=235
Reply from 212.159.108.127: bytes=32 time=136ms TTL=235
Reply from 212.159.108.127: bytes=32 time=226ms TTL=235
Request timed out.
Reply from 212.159.108.127: bytes=32 time=79ms TTL=235
Reply from 212.159.108.127: bytes=32 time=258ms TTL=235
Reply from 212.159.108.127: bytes=32 time=93ms TTL=235
Reply from 212.159.108.127: bytes=32 time=179ms TTL=235
Reply from 212.159.108.127: bytes=32 time=202ms TTL=235
Reply from 212.159.108.127: bytes=32 time=159ms TTL=235
Reply from 212.159.108.127: bytes=32 time=124ms TTL=235
Reply from 212.159.108.127: bytes=32 time=230ms TTL=235
Reply from 212.159.108.127: bytes=32 time=158ms TTL=235
Reply from 212.159.108.127: bytes=32 time=249ms TTL=235
Reply from 212.159.108.127: bytes=32 time=218ms TTL=235
Reply from 212.159.108.127: bytes=32 time=129ms TTL=235
Reply from 212.159.108.127: bytes=32 time=227ms TTL=235
Reply from 212.159.108.127: bytes=32 time=177ms TTL=235
Reply from 212.159.108.127: bytes=32 time=185ms TTL=235
Reply from 212.159.108.127: bytes=32 time=139ms TTL=235
Reply from 212.159.108.127: bytes=32 time=222ms TTL=235
Reply from 212.159.108.127: bytes=32 time=116ms TTL=235
Reply from 212.159.108.127: bytes=32 time=219ms TTL=235
Reply from 212.159.108.127: bytes=32 time=166ms TTL=235
Reply from 212.159.108.127: bytes=32 time=286ms TTL=235
Reply from 212.159.108.127: bytes=32 time=110ms TTL=235
Reply from 212.159.108.127: bytes=32 time=215ms TTL=235
Request timed out.
Reply from 212.159.108.127: bytes=32 time=137ms TTL=235
Reply from 212.159.108.127: bytes=32 time=237ms TTL=235
Reply from 212.159.108.127: bytes=32 time=147ms TTL=235
Reply from 212.159.108.127: bytes=32 time=101ms TTL=235
Request timed out.
Reply from 212.159.108.127: bytes=32 time=932ms TTL=235
Reply from 212.159.108.127: bytes=32 time=176ms TTL=235
Reply from 212.159.108.127: bytes=32 time=246ms TTL=235
Reply from 212.159.108.127: bytes=32 time=183ms TTL=235
Reply from 212.159.108.127: bytes=32 time=140ms TTL=235
Request timed out.
Reply from 212.159.108.127: bytes=32 time=134ms TTL=235
Reply from 212.159.108.127: bytes=32 time=122ms TTL=235
Reply from 212.159.108.127: bytes=32 time=205ms TTL=235
Reply from 212.159.108.127: bytes=32 time=255ms TTL=235
Reply from 212.159.108.127: bytes=32 time=212ms TTL=235
Reply from 212.159.108.127: bytes=32 time=173ms TTL=235
Reply from 212.159.108.127: bytes=32 time=225ms TTL=235
Reply from 212.159.108.127: bytes=32 time=181ms TTL=235
Reply from 212.159.108.127: bytes=32 time=143ms TTL=235
Reply from 212.159.108.127: bytes=32 time=164ms TTL=235
Reply from 212.159.108.127: bytes=32 time=247ms TTL=235
Request timed out.
Reply from 212.159.108.127: bytes=32 time=133ms TTL=235
Reply from 212.159.108.127: bytes=32 time=231ms TTL=235
Reply from 212.159.108.127: bytes=32 time=186ms TTL=235
Reply from 212.159.108.127: bytes=32 time=142ms TTL=235
Reply from 212.159.108.127: bytes=32 time=188ms TTL=235
Reply from 212.159.108.127: bytes=32 time=138ms TTL=235
Reply from 212.159.108.127: bytes=32 time=187ms TTL=235
Reply from 212.159.108.127: bytes=32 time=269ms TTL=235
Reply from 212.159.108.127: bytes=32 time=146ms TTL=235
Reply from 212.159.108.127: bytes=32 time=234ms TTL=235
Reply from 212.159.108.127: bytes=32 time=674ms TTL=235
Reply from 212.159.108.127: bytes=32 time=221ms TTL=235
Reply from 212.159.108.127: bytes=32 time=128ms TTL=235
Reply from 212.159.108.127: bytes=32 time=209ms TTL=235
Reply from 212.159.108.127: bytes=32 time=108ms TTL=235
Reply from 212.159.108.127: bytes=32 time=121ms TTL=235
Request timed out.
Reply from 212.159.108.127: bytes=32 time=126ms TTL=235
Reply from 212.159.108.127: bytes=32 time=125ms TTL=235
Reply from 212.159.108.127: bytes=32 time=203ms TTL=235
Reply from 212.159.108.127: bytes=32 time=195ms TTL=235
Reply from 212.159.108.127: bytes=32 time=268ms TTL=235
Reply from 212.159.108.127: bytes=32 time=92ms TTL=235
Reply from 212.159.108.127: bytes=32 time=160ms TTL=235
Reply from 212.159.108.127: bytes=32 time=253ms TTL=235
Reply from 212.159.108.127: bytes=32 time=210ms TTL=235
Reply from 212.159.108.127: bytes=32 time=107ms TTL=235
Reply from 212.159.108.127: bytes=32 time=190ms TTL=235
Reply from 212.159.108.127: bytes=32 time=98ms TTL=235
Reply from 212.159.108.127: bytes=32 time=88ms TTL=235
Reply from 212.159.108.127: bytes=32 time=228ms TTL=235
Reply from 212.159.108.127: bytes=32 time=170ms TTL=235
Reply from 212.159.108.127: bytes=32 time=141ms TTL=235
Reply from 212.159.108.127: bytes=32 time=245ms TTL=235
Reply from 212.159.108.127: bytes=32 time=200ms TTL=235
Reply from 212.159.108.127: bytes=32 time=135ms TTL=235
Reply from 212.159.108.127: bytes=32 time=97ms TTL=235
Reply from 212.159.108.127: bytes=32 time=157ms TTL=235
Reply from 212.159.108.127: bytes=32 time=244ms TTL=235
Reply from 212.159.108.127: bytes=32 time=131ms TTL=235
Reply from 212.159.108.127: bytes=32 time=149ms TTL=235
Reply from 212.159.108.127: bytes=32 time=273ms TTL=235
Reply from 212.159.108.127: bytes=32 time=1060ms TTL=235
Reply from 212.159.108.127: bytes=32 time=276ms TTL=235
Reply from 212.159.108.127: bytes=32 time=94ms TTL=235
Request timed out.
Reply from 212.159.108.127: bytes=32 time=132ms TTL=235
Reply from 212.159.108.127: bytes=32 time=109ms TTL=235
Reply from 212.159.108.127: bytes=32 time=100ms TTL=235
Reply from 212.159.108.127: bytes=32 time=192ms TTL=235
Reply from 212.159.108.127: bytes=32 time=216ms TTL=235
Reply from 212.159.108.127: bytes=32 time=191ms TTL=235
Ping statistics for 212.159.108.127:
Packets: Sent = 236, Received = 228, Lost = 8 (3% loss),
Approximate round trip times in milli-seconds:
Minimum = 71ms, Maximum = 1060ms, Average = 190ms
1 REPLY
RE: Connection Problem?
If you continue to have a problem with your account, please let us know via the Contact Us system. Include all the details you have and we will happily investigate this issue for you further.
Also may I ask that you do not post long logs to the forums. This sort of technical information is needed in our Contact Us system.
Regards,
Dave
| David Scarpa...................Unmetered & ADSL solutions
| Technical Support.....................for Home & Business
| PlusNet Technologies Ltd............@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
