Connection Hanging
Snarf
Connection Hanging
Hopefully someone has a simple answer to this.
My connection will sometimes pauses (i.e. loading web pages will hang), however if I activate the phone attached to the same filter, the moment I hear the dial tone my connection will start going again instantly.
Is this something to do with a dodgy filter in the wall or is there another problem. Alternatively, is this just a "feature"?
Fixes: 9
Connection Hanging
Sounds like a micro filter that has gone a bit cranky.
Do you use an extension lead or any double phone socket blocks? - Those have a negative effect too.
Snarf
Connection Hanging
It's just a filter plugged into an upstairs phone socket - there's always the chance that the extension upstairs could be dodgy. At some point I should really try connecting the router downstairs to the master socket and see what sort of link speed I get.
Fixes: 8
Connection Hanging
You said the filter is in an upstairs phone socket. You have got a filter in the downstairs master socket as well haven't you. You can only get away without a filter if you have no phones, faxes, sky boxes etc plugged in downstairs.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Snarf
Connection Hanging
Yes, everywhere there's a phone there's a filter Smiley
James
Connection Hanging
Are you connecting directly to your master socket? The best way of proving whether it's your wiring/filters is to plug a brand new filter directly into the test socket behind the master faceplate, and plug your modem and your phone into the filter.
Fixes: 8
Connection Hanging
I'd suggest the first thing you need to do is disconnect the extension and try directly in to the master socket.
Snarf
Connection Hanging
Hmm, checked all three internal phone sockets and none of them have a master socket in, is it possible it's located elsewhere or I don't have one? The house is a mid 80's end of terrace.
James
Connection Hanging
Try the one nearest to the front entrance to your house as a starting point.
Snarf
Connection Hanging
Yup checked there, behind the socket were just a bunch of wires 2 or 3 of which were wired into the socket, but no other visible plugs.
Fixes: 8
Connection Hanging
Can you see where the wire comes in to your house from outside?
Also cable coming in often I think has eight wires and the extensions have four. That might help you sort out which is which.
Snarf
Connection Hanging
I believe I've found where the cable comes in. The socket nearest to the entrance certainly has more wires in it, but I'm certain there is no master socket there - perhaps I'll have a bit more of a hunt later on.
James
Connection Hanging
Quite often, some of the older wired houses won't have a test socket inside the master socket itself, but as long as you are able to locate your master socket, and test from there, that's the best yu can do!
