Connection Drop???
Connection Drop???
Did anyones connection just drop? Not the sync just to PN, i was typing a post and got looged out of messenger, thought nothing of it tried to go to another website and couldn't unplugged and replugged my modem and it worked again!
csogilvie
Connection Drop???
Nope, my connection seems fine here... don't see any indications its dropped in either IRC or my router logs which indicate its been up for > 9 days.
Connection Drop???
There was a pretty sharp drop on the Utilisation Graphs this morning, which would suggest some users dropped.
Connection Drop???
Nothing showing atm looks like it was much earlier. Must've just been me...
Plusnet Staff
Plusnet Staff
Connection Drop???
The drop earlier this morning was probably the MSO in Edinburgh
http://usertools.plus.net/exchanges/mso.php?id=18902
Connection dropout
Mine is driving me mad. Since 22/8/05 my download speed has dropped to an average of 200kbps on a 1 meg connection and the connection drops out several times an hour. I have just run two antivirus and two ad-ware progs and all is fine but the connection has dropped out 7 times in 20 minutesHuh
Connection Drop???
steve1894: I'd check your attenuation figures and do a BT (not PN) speed test. If the BT speed test checks out ok, it may be time to raise a ticket.
