Connect at 5.2mb download at 2mb?
Hi
Thanks for the upgrade last week. However, my router syncs at 5.2mb yet I can only attain download speeds of up to 2mb. (220, 240k/ps)
Any ideas as to why this might be?
craigbrass
You say it was only last week you got upgraded?
If this is the case then you need to wait a little while longer (up to 10 days) for PlusNet's systems to update with the new speeds. You what PlusNet have by going to https://portal.plus.net/my.html?action=stable_rate
Also, if it is peak time you will likely not get full speed because of contention on the exchange ant at PlusNet's end.
Ok thanks.
The router always syncs at around 4.8 - 5.2mb so im guessing I am capable of more than 2mb speeds. I have tried reconnecting but I still get the same speed.
I will wait until wednesday Smiley
