Confusion over bw management and sustainable useage
Now I am confused...
Option 1 Premier
10gb before management kicks in, and blocked file transfers 15gb+.. ok now thats easy to understand.. but when I look at the sustainable useage policy
Premier
Option 1 24GB - warninging email 30GB - restrictions applied
Does this just not contradict the first limitsHuh?
Mand
Hi
We have two systems running together to manage the network.
The first is the traffic management policy, which as you say has light management applied after 10GB. Any management will be lifted at your next billing date.
Additionally there is the Sustainable Usage Policy, which gives 30GB at peak times and management is then applied across all traffic at peak times.
If either of these scenarios relates to your account you will be sent warning emails and further emails as you move through the management levels.
Well, that's the plan any way :lol:
