Come On Plusnet Give An Honest Answer
fraval
Speed At 18.50[Tues 20th]
Download Speed: 119 kbps (14.9 KB/sec transfer rate)
Upload Speed: 54 kbps (6.8 KB/sec transfer rate)
Can You Not Give An Honest Answer When This Is Going To Be Sorted Out
I Expect You Will Want Your Full Months Money
Or Will There Be A Rebate This MonthHuh?
Dont tell me to upgrade to premier or PAYG There in the same boat,why should I upgrade the service was fine until 3 weeks ago
1 REPLY
I'm locking this thread as there are already plenty of threads relating to speed issues including this one that you started -
https://portal.plus.net/central/forums/viewtopic.php?t=53844
Chris
