Changing e mail address
kiasu
Does anyone know if it is possible to change the main part of ones Plusnet e mail address?
I am now receiving almost 100 spam e mails per day and it is driving me nuts.
Impossible to filter most of these out without some genuine ones ending up in the bin.
I know that if I change e mail address they will gradually build up again but I plan to set up a free e mail address for registering on most websites that will hopefully avoid it getting too bad.
Regards
Kiasu
Plusnet Staff
Plusnet Staff
Fixes: 159
If you are using on specific address before the @ symbol then you could set up a mailbox for this. Your current mailbox, kiasu@kiasu.etc... will receive anything sent to @kiasu..
Therefore to cut down on the SPAM you should set up specific addresses, eg mail@kiasu... would only receive mails to mail@
We could then blackhole the rest of the mails for you.
If I didn't explain it very well then have a look at http://www.plus.net/support/security/spam/spam_protection_guide.shtml
 Chris Parr
 Plusnet Staff
kiasu
Att Chris at Plusnet
Many thanks for this Chris,
I have turned on the Spam setting in Plusnet.
Also, I have 3 e mail addresses that I use prior to my @kiasu address.
These are:
mark.phillips@
kiasu@
the_wise_old_owl@
How do I register these with Plusnet to avoid any other e mails arriving without these correct address please.
PS
For the last few weeks practically all of my e mails received, including genuine ones, have the little paperclip symbol attached to them even though there are no enclosures.
Would this possibly be that I recently changed Norton to AVG protection?
Many thanks
Mark
OldDave
kiasu
The attachment is probably the AVG certification that the E-Mail is virus free.
you can turn this off by going to AVG Control center --> E-mail scanner --> Configure
than unselect the Certify Mail tick box
You can set up your mail boxes via this menu;
https://portal.plus.net/my.html?action=myemail
Chilly
Re: Att Chris at Plusnet
Create mailboxes with these names here and then raise a ticket with PN to "blackhole" your "catchall" mailbox.
