Change of Usernames
Change of Usernames
Following the report on the security breach how long will it be before we know if/when usernames can be changed?
Fixes: 69
Change of Usernames
Did you see this that was posted yesterday.
My understanding is that we will have a Help Assistant path set up early next week that will allow you to request a change of username.
Kind Rgds,
Plusnet Products Team
Change of Usernames
Thank you Bob for your prompt reply. Have followed the link and noted the procedure. If anyone would prefer to use a Plusnet address instead of F9 would this be allowed or have any implications e.g. referrals?
Fixes: 69
Change of Usernames
I can't see there being a problem with this. The only thing extra it involves is having to place a modify order with BT to change the 'realm' you use to connect to broadband with.
Moving referrals is a PITA but it's no more difficult moving from PlusNet > PlusNet than it is F9 > PlusNet.
Kind Rgds,
Change of Usernames
Just a note for anyone who wishes to change username following the webmail security breach. I set up a new account as advised but having read the pathway in Help Assistant found that this is not possible for those of us who use Plusnet/F9 telephone service. Perhaps I was a bit precipitate but I now realise that I needn't have bothered.
