Change of Product?
Change of Product?
Hello
I'm currently on Premier £21.99 tariff at the moment and using about 4GB a month for gaming and web.
I'm thinking of moving to the 4GB Pay As You Go, as I don't think I am using it to it's potential.
Can anyone envisiage any problems doing this? Is it the right thing to do as my usuage is decreasing, not increasing.
Will I be charged a regrade fee? I have been with PlusNet for about 3 years or so.
Also, is it true PAYG has the highest priority as PN say,m and I quote: "you are paying for what you get"?
Also, I suppose I will lose my 4 static IP's?
Thanks in advance.
Change of Product?
See Jelv's excellent post on this subject;
http://portal.plus.net/central/forums/viewtopic.php?t=52795
As PAYG also has a static IP address so you should not lose them, but I would check by asking support directly with a ticket.
Chilly
Fixes: 8
Change of Product?
I'm pretty sure that IP blocks are available under PAYG.
If you go straight to 4GB PAYG will be charged a regrade. If you go to 12GB PAYG and then drop to 4GB a month later you will avoid the regrade fee.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Change of Product?
Cheers
Have moved over to the 12Gb and will probably chose the 6GB just incase...
Thanks for the help - it is appreciated
Smiley
Plusnet Staff
Plusnet Staff
Change of Product?
Yep, the IP block should remain the same on that type of change. You'd only lose an IP block if you move to Broadband Plus, a single IP address would change if you moved between business and residential accounts or to Broadband Plus (or from an old Home Surf account).
