Change my static IP address?
aeroalfie
I had this problem a short while ago but now its back - my incoming internet connection is always active even when im not - my fire wall is blocking what ever activity it is ( seems like loads of random IP's?) but I understand even though it is been blocked it is still chewing up my bandwidth. This first stated as soon as I switched account and got a different static IP address with it - could this be in some way related to the IP I have been assigned.
Should i raise a ticket?
You can't change your static IP unless you connection is being severly affected (DDos or compromised in some other way).
What you are seeing is normal 'internet noise' that everyone gets. Changing IP will not stop this and your firewall is doing what it was designed to do, block it.
aeroalfie
Hello peter i had a different static IP on my old account and it never had this ammount of incoming activity - just over the past week or so there wans't this activity?
aeroalfie
Just to update my fire wall has logged 7300 incomming connection attempts in 10 minutes :?
Fixes: 8
Do you (or have you) used a P2P application?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
MysteryFCM
Get yourself a packet monitor - this will help determine where the traffic is coming from, what they contain, and what they are directed at;
http://www.wfshome.com/wit.htm
aeroalfie
Elvin: Yes, last night/this morning - currently turned off and blocked in/out through firewall
mysteryfcm: thanks for the link will give it a go now.
Fixes: 8
Are you sure that these are not attempts by peers to download from you?
MysteryFCM
As elvin mentioned, if you are or have run P2P apps, chances are these are simply attempts to connect to the P2P client (I get these extremely frequently due to my brothers love of DC++).
This is almost certainly connection attampts from P2P users. There systems are not informed that you are disconnected.
aeroalfie
So this is people who I was connected to via bit torrent - what do I have to do stop just wait until they turn off their client or finish what ever torrent we were on?
Fixes: 8
It's not just people who you've connected to - it's anyone in the world who wants the files you've got - that's the whole idea of Peer to Peer.
craigbrass
There is a way to get your static IP changed. Ask to get a block of 4 IPs and then leave it a few weeks and then ask to go back down to 1. That way, you end up with a new IP in the end. Worked for a friend of mine anyway Cheesy
Fixes: 8
But if he's using P2P there's no point. As soon as he starts using it on his new IP peers will start trying to connect to him.
