Capped Speeds
Capped Speeds
First of all I'm a complete noobie here but over the weekend my broadband suddenly went down to 125kbps. Yesterday and today it has been up at 240kbps. I have read about weather been a cause of slow sppeds (and it has been quite bad here) and BT capping certain lines because of sync problems and I just wondered if anyone here has had similar problems?
Prior to the weekend it was working fine at 1.5mb (a poor speed i know, but it is all my line will support!) and had entountered no problems
Any responses appreciated.
Nick
James
Capped Speeds
Can I ask you to have a read of this as I think it should shed some light on the problems that you're seeing:
http://community.plus.net/comms/2007/07/02/broadband-speed-faults-how-to-diagnose/
Basically, your router or modem keeps on "resyncing" with the exchange at low speeds. This then causes BT to lower the profiled speed on your line, which is then recalculated after 3 days. The last resync events I can see on your line are 288, 160, 160, 160 & 288Kbps. To try to improve this, I'd recommend trying to use a different microfilter and ensuring that you are connected to your master socket.
Let me know how you get on.
Capped Speeds
Thanks James
It all works as normal now.
Cheers
Nick
