Capped Downloads?
Capped Downloads?
Hi all Smiley
Is there any way I can check if I have any restrictions on my downloads? I can't download anything greater than 30 kB/sec at the moment (I'm connected at 5184/44Cool. I recieved a mail in my last billing month warning me that I had exceeded 11gig and that restrictions would come into place should I exceed 13gig but nothing after that.
thanks
Gareth.
sophos9
Capped Downloads?
Hey man, can you run some speedtests and post up the results. Then run a BT speedtest
http://speedtester.bt.com
eNJoy
Capped Downloads?
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 283 kbps
DSL connection rate: 448 kbps(UP-STREAM) 5184 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 177 kbps
Re: Capped Downloads?
Hi all SmileyI can't download anything greater than 30 kB/sec at the moment (I'm connected at 5184/44Cool.
Ah the magic 30k figure crops up yet again...join the club.
bobbygeorge
Capped Downloads?
well,
thats were your 30kB/s comes from,
your BRAS profile may well be stuck..
whats your stable rate set at by plusnet?
Capped Downloads?
Your current broadband speed is 500 Kbps
Mand
Capped Downloads?
A lower profile than your sync speed can often occur for a couple of days.
If there was an issue which caused many resyncs, or problems on your phone line, even for a relatively short period, your BRAS profile will drop automatically. This should increase within 3 days, and should then reflect your sync speed.
Moderators note by John (johnessex) Duplicate post removed.
Capped Downloads?
I take it that is the MSR reading, in fact I am positive.
Plusnet's MSR seems to go no lower than 500Kbps, even when my BT IP Profile was stuck at 128Kbps for weeks, the Plusnet MSR still stated 500Kbps.
Capped Downloads?
Thanks everyone for the pointers and Mand for the confirmation. I'll monitor it for a few days and see Smiley
