Cannot create Mailbox/.
I'm trying to create a mail box called snow.
But everytime I create it i cannot access it via webmail or thunderbird.
I have sucessfully created one called snow.
I'm getitng this error on webmail: Username/Password match not found, please try again.
using login carlsav+snow
thanks
Ok it just worked. Ignore me.
JonathanW
Just for reference, it takes about half an hour for any mailbox you create to become active, and a similar ammount of time if you change the password on one of them.
