Cannot check meails
Cannot check meails
I currently use thunderbird email client
At present the thunderbird is minimised.
I cant seem to access thunderbird...not sure why..i tried maximising it but no luck...tried reinstalling...done adware and virus scans...still no luck
Any ideas
Ben_Brown
Cannot check meails
That doesn't sound too good. I use Thunderbird myself but have never seen that sort of behavour.
Did you reboot after uninstalling it, and before reinstalling it?
If that doesn't work I'd try backing up the following folder, then uninstall, delete the folder, reboot and reinstall.
Windows:
C:\Documents and Settings\{user}\Application Data\Thunderbird\
Linux (and possibly Mac):
~/.thunderbird/
Cannot check meails
IVe tried all that...and it never worked...
I tried opening up outlook but the file extension outlook uses is .pst and it wotn work
so dont know what to do realy
got option to back up the folder and do a clean install but thats my last option
