Can't connect
Kakkoii
Can't connect
Switched on my computer today and tried to connect to PlusNet, but it says "Username and/or password is incorrect".
It was working fine last night, and I didn't change the connection details at all. I've turned my firewall off and restarted a few times and still it wouldn't work.
Can't connect
Just a hunch but if you are on PAYG, then try changing to last part of your username to; @plusdsl2.net
Also give @plusdsl.net a try.
See this thread about the rin trial;
http://portal.plus.net/central/forums/viewtopic.php?t=54722
Chilly
Kakkoii
Can't connect
I'm on Premier Option 1 2MB.
NigelWood
Re: Can't connect
For privacy reasons I can't properly respond your query here. I've opened ticket 21628013 on your account with the information you need.
Kakkoii
Can't connect
Fixed now. Absolutely have no clue what was wrong.
Weird...
Plusnet Staff
Plusnet Staff
Fixes: 159
Can't connect
Might have just been something as simple as your modem/router losing the settings.
 Chris Parr
 Plusnet Staff
