Can't access Portal From Home
At home i am using plusnet as my provider (£21.99 package) and i, for some reason cannot access this portal or www.plus.com either, i just get a page not found, although i can access all other webpages. any reason for this as i can access it at work (where i am now) via btopenworld BB
Marc
jberry
There shouldn't be a problem accessing the portal. The only things that I can advise are to clear the cache on your machine and delete all of you cookies.
Also, try accessing the site using http://portal.plus.net.
Regards,
ok ill try that, third day of no access tot he portal from home :? , hmm. ah well. ill clear me cache then Smiley cheers
marc
(will update you further if it works etc)
Ianwild
Is it just the plus.com domain that doesn't work?
Have you tried http://portal.plus.net ?
This could potentially be all manner of things, but it isn't a problem Ihave heard of very often so there is no obvious answer.
Can you get to our other portals (http://www.force9.net , http://www.free-online.net)?
Regards,
as i am not at home and wont be till late on sunday i have no idea if i can get onto force9, although i did try http://portal.plus.net and it didnt work, didnt try freenet.
hmm i couldnt ping www.plus.net either, timed out.
i did a tracert ill post the findings of that when i get home
marc
Maybe completely unrelated, but I had a similar situation recently. You can read my problem and cure in the Computers & Hardware section of the forum (a few weeks ago) under the title "strange router problem".
right im home now and all is fine, just wanted to update you guys
ta very much
marc
