Can someone help me with my router settings please,,
Had to reset my router to factory default, can someone help me with the settings for adsl always on, need to know the following,,, Netgear dg384g
1-encapsulation setting
2-internet ip address, which do i select from the 2 options,either get dynamically from isp, or use static ip, then there is the box for the ip address,
3--domaine name serveraddressthe 2 options are either get automatically from isp or use the DNS servers, again there is the box for the address to be entered,, some help greatly apperecated,,and needed,,thanks
Try this linky
That info took some finding ..... should this be in your Connection Settings under My Account, along with the server names and ip's ?
Thanks mate, already checked them, they are for modem settings, mine are router settings for always on,,,anyway found the problem,,,,no thanks to force9 support, was a faulty pci card, bummer,,,,,took some finding,,,but got there in the end, 48 hours since i asked the ?? to sipport, still awaiting a reply,,,anyway thaks for replying
David_W
Same router I have. Allow the Netgears wizard to auto detect, then change encapsulation to VC-Based and Encapsulation to PPP over ATM, everything else you dont need to touch.
