Can not create message
Is there a bug? Can not create an message, press the new message and nothing happens. Can reply to message's though.
Others wise not bad a little slow
James
What is your browser & version?
What view and protocol did you select on the login page?
I suspect you hav a pop-up stopper which is stopping the compase pop-up window from appearing. Either turn the pop-up stopper off or configure it to allow popups for the Beta webmail and see if that works.
problems solved
Thanks for the advice. Turned off pop-up's and now works fine.
James
