Can anyone check out these speed stats.....
and let me know if I need to raise a ticket?
From http://portal.plus.net/my.html?action=stable_rate today, 23/03
Your High-speed Broadband Service
Your current broadband speed is 5500 Kbps (varies between 5500 and 6500)
I'm 1.3 km from my exchange (Sheffield Broomhill). It's been red for a few weeks which it why I've not raised this before. It's now green and there's no real improvement.
Router stats: 14:36, 23-03-2007
SNR Margin (dB): 8.6 26.0
Attenuation (dB): 39.0 22.0
Output Power (dBm): 11.9 19.6
Attainable Rate (Kbps): 6624 1212
Rate (Kbps): 6048 448
(first figure is downstream, second up.
Interleaving depth is 16.
BT test done at 18:20, 17-03-2007:
IP profile for your line is - 5000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 7616 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 3926 kbps
BT test done at 12:30, 18-03-2007
IP profile for your line is - 5500 kbps
Actual IP throughput achieved during the test was - 3980 kbps
BT test done at 14:23, 23-03-2007
DSL connection rate: 448 kbps(UP-STREAM) 6048 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 4304 kbps
Plusnets Speed test results
Date Speed Achieved (kbps)
23-03-2007 14:32:52 1899.2
23-03-2007 14:32:25 2000.5
23-03-2007 14:32:04 2024.9
23-03-2007 14:26:33 1369.5
22-03-2007 19:59:57 700.3
22-03-2007 00:19:01 1091.3
20-03-2007 07:19:54 1308.7
20-03-2007 07:19:26 1145.1
19-03-2007 22:50:30 819.1
19-03-2007 22:50:06 681.6
19-03-2007 21:39:04 155
19-03-2007 21:38:30 273.6
18-03-2007 23:23:57 881.9
18-03-2007 23:16:38 971.8
18-03-2007 23:16:13 1065.4
18-03-2007 23:15:42 801.8
18-03-2007 12:30:38 1173.6
18-03-2007 12:29:58 1419.9
18-03-2007 12:29:30 1571.7
18-03-2007 12:28:59 1286.8
mybroadbandspeed.co.uk today
Today 14:30 1631 kbps (203.9 KB/s) 365 kbps (45.6 KB/s)
Today 14:29 1988 kbps (248.5 KB/s) 373 kbps (46.6 KB/s)
Today 14:28 1659 kbps (207.4 KB/s) 376 kbps (47 KB/s)
Today 14:28 1555 kbps (194.4 KB/s) 359 kbps (44.9 KB/s)
The actual speeds I'm getting (measured by Bandwidth monitor) are best reflected by Plusnet's own tester.
I'd be happy to be getting the 4000kps that BTs tester suggests I should at least sometimes.
Cheers
Tim
Have you tried Speedtest.bbmax and Speedtest.net
The amsterdam server on bbmax is more responsive at the min, so I have heard.
James
Oddness. You're profiled correctly at this end.
Try the other speed testers as suggested and see if you get closer to the value shown on the BT Speedtest.
Fixes: 8
The Amsterdam server is speedtest.net not bbmax
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Oops Shockedops:
Oops Shockedops: Must be my age Wink
HI,
the bbmax speedtest gives me
Date of Speed Test: 2007-03-23 17:25:02
Download Speed: 2416 kbps (302 KB/sec transfer rate)
Upload Speed: 381 kbps (47.6 KB/sec transfer rate)
I'm on PAYG by the way
I suppose you could try the old BT speedtest, although it dosnt work for alot of people now, but its maybe worth a try, to see what you get off the PN network.
http://www.kitz.co.uk/adsl/btwspeedtest.htm
Many thanks for your help, hesketh14 (and James), but what will further speed tests tell us?
My actual downloads, best speeds, are substantially less than my sync and stable rates suggest I should be able to get, and also less than BTs speedtester.
If kitz's test give higher or lower speeds, what will we have learned?
Cheers,
Tim
Fixes: 8
There have been a couple of people recently where the speeds are being limited by poor MTU and RWIN settings. Have you checked these out?
The tweak test at http://www.dslreports.com/tweaks will check your settings and make recommendations. It also has Dr TCP which is a tool for making changing these settings easy.
