CLI Settings
CLI Settings
Hello
Why would I might want to modify my CLI settings? Does this mean I can use my PLusNet BB at various locations?
Regards
Paul
James
CLI Settings
It's for your dialup access.
CLI Settings
To expand on James's comment.
There are two dial-up services available to broadband customers;
0845 prefix, which is a general dial-up service and can be used from any phone line. You pay for this access via your phone bill.
0808 prefix, which is used as an alternative dial-up service should you be suffering a connection fault. Once you have opened a fault ticket. PlusNet will activate this for you (if appropriate) so that you can still connect. This requires the CLI to be correct, as the charges for this service are paid by PlusNet. Once the fault has cleared PlusNet will remove access to this number.
Chilly
lank111
CLI Settings
Wow, i didnt know this, nor would i expect alot of other customers having connection issues!
I'm happy with my connection at the moment and have done for a while now, its not the fasted but its stable and the quality is good!
i know BT is largely to blame for these problems that a small number of customers having issues.
It all ISPS, plusnet are one of the best! who else offers a 0808 alturnative number, fast and dedicated support, total network honestly!
keep it up =)
