CGI - php- MySql
CGI - php- MySql
Hi
Trying to play with CGI-PHP-MySql
I have activated MySql and CGI
I recieved an email with MySql details
Have heard nothing from CGI, But I can transfer files to my cgi space (chmod 755)
However all I get is internal server errors.
(I have used your sample php script with my details.)
What have I done wrong?
Cheers Gary
RE: CGI - php- MySql
> Cheers Gary
We do not officially support PHP but we can of course still have a look into your issue.
Firstly, apologies that you did not receive your CGI activation mail. The account is fully enabled but we did not communicate that effectively so sorry from CS.
I have put a php script on your account and set permissions to 755. I have named it test.php and it functions correctly. You can use this for reference to analyse where the problem lies.
I hope this helps.
Regards, Techsupport.
| Torsten Dettlaff........................Unmetered & ADSL solutions
| Customer Support.................................for Home & Business
| PlusNet Technologies Ltd....................@ http://www.plus.net
+ ------ My Referrals - It pays to recommend PlusNet ------ +
I will have a look at your example.
(I did not think you fully supported php etc., but knew you could not resist a challange!)
Cheers
Gary
> Thanks
No problem. Feel free to get back to us with any further questions.
Regards, Torsten.
> Regards, Torsten.
> | Torsten
I edited my original file and put a space after
#!/usr/local/bin/php3
then it worked!
I noticed your file had "strange" characters instead of spaces(carrige returns?). What/how?
I am editing with Notepad.
Gary
> Thanks
> then it worked!
> Gary
This file is created in the pico text editor within an ssh shell connected to criticalmass. I'm uncertain how notepad will interpret these characters.
Regards, Torsten.
Changing the subject slightly, but still looking for an answer, I'm continuing to get strange characters when I read my portal problem page. The character & reads &amp and the character " reads "quot. Keyboard and default font etc. etc. all checked. Anyone any ideas?
Regards,
Mark Henderson.
(thetop)
www.sussexbridalcars.co.uk
Morning Mark,
Not sure exactly what's happening there, seems like a coding issue. I'll raise the problem with our developers for you.
Regards
| Dean Wood..........................Unmetered & ADSL solutions
| Customer Support Agent..............for Home & Business
| PlusNet Technologies Ltd..........@ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
I think they're do a htmlspecialchars
on the string to convert iffy chars like < >
to their &lt and &gt etc.
Have a shufty here
http://www.php.net/manual/en/function.htmlspecialchars.php
Cheers
Liam
> Morning Mark,
> Regards
> to their < and > etc.
> Have a shufty here
Thanks for the further advice here Liam.
Regards, Torsten.
Mark,
With regards to the strange characters in Contact Us this is a problem that our developers are now aware of. A fix will be implemented shortly.
Thanks for pointing the error out to us.
Regards
No Problem, but I must say I've told you b4 and more than once!
I await the "fix".
Cheers to Liam for advice given.
BTW-Liam you asked the same question about lite accounts duration on 2 threads (including twice within the same thread but I dont blame U as cust support answered with duff info anyway).
R U going mad or just another norm polusnet customer!
TTFN.
> I await the "fix".
> TTFN.
I had discovered the art of home brew Smiley
ooooooooohhhhhhhhh my head !
I saw the double posts, but as everything seemed kinda double :p at that time,
I reckoned it was just the one post
I say.........
Cheers
Liam
Liam
Murky Home Brew ... ick, the memories...
> I say.........
> Cheers
> Liam
> Liam
Actually,
Remembering your posts from a couple days back, you do know you can get a Lite account on a month-by-month basis, don't you?
If you want more info, just ask.
Regards,
Mike
Mike
| Mike Grice........................Unmetered & ADSL solutions
| Customer Support...........................for Home & Business
| PlusNet Technologies Ltd...............http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----------
