Broadband plus question
cfcws
Can I send emails from Outlook if I am on the Plus product?
Could someone create a comparison chart including the old products so that we can decide if we want to switch?
Re: Broadband plus question
You certainly can.
Can I ask what made you doubt this?
Edit . Your area of doubt has been explained by colin.
csogilvie
Yes. The SMTP option that is not included is the ability to get mail delivered directly to a server you run on your internet connection. With Broadband Plus, the only option is to go through PlusNet's mail server for incoming mail.
cfcws
Reply
Yes that explains it thanks
Any chance of a comparison for my old 18.99 plan?
