Broadband phonecalls??
Could someone explain this. When I checked my broadband usage I saw that the chart said I have used 4 mb. of broadband phonecalls this month. I do not have plustalk or any other broadband based phone facility. So where does this 4 mb of usage come from?
Cheers
do you use wireless?Huh
Yes ,I have a wireless router.
that could be the problem then if the wireless security is not quite right then somebody could be using your connection
I cannot see how as my nearest neighbour is over a mile away
Moderators note by John (johnessex) Duplicate post removed
The internet contains a lot of background noise, and most likely the small figures showing up as usage for traffic types you don't use are just as a result of that.
Ta
Yep mine also shows a small amount of "Telephone" traffic and I dont use it either, so it's probably just background noise as suggested.
Unless it starts to become large amounts then just ignore it.
Right at the foot of the View My Usage page, PN mention this, although its in the greyed text right at the bottom.
There is a link to an explanation (which doesn't go into much detail here)
