Broadband Interleaving
Just been checking through my connection settings this evening and I notice interleaving is switched on? I know for a fact it was switched off the last time I looked :?
Is there something strange going, why would PN enable it for me without asking?
Dean
when was the last time you looked?
Was it before the 13th September when the house move process completed? (Not sure if interleaving is turned on by default on a house move but I'll find out.)
If it was after that date - I'll have to dig deeper into processes and system.
Dean
Hey, yep it’s been a while since i looked, probably early September as I was out of the country while the dsl was moved. Pain free Wink
I appreciate your help.
So did you check? Smiley
csogilvie
Something tells me BT can auto-enable interleaving if there's a period of disconnects (or resynching) so that could have happened?
Nope, my connection has been pretty stable since we moved house, not noticed any random disconnects.
Actually, can you help me to understand these line rates. What speeds should i be achieving?
Upstream Downstream
Noise Margin 25 dB 6.5 dB
Output Power 12 dBm 20 dBm
Attenuation 29.5 dB 48 dB
csogilvie
Nope, unfortunately not as I've never quite managed t oget my head around the line rates etc. Sad
Dean
Want to speak to someone in the morning and understand the process before I open my mouth and talk Link:censored :-)
you'll allow me that wont you :-)
Dean
Moderators note by John (johnessex) Bypassing of swear filter removed. See the Link:rules
What speed are you achieving?
Are you on BT (up to 2Mbs), BT Max (up to 8Mbs) or LLU (up to 8Mbs)?
The figures you quote are showing what they end up as (in the case of downstream SNR) once synced.
A wild guess is maybe 3 -> 3.5Mbs down, 448Kbs up.
And I do understand what the figures mean Tongue
Nor me lol, thanks anyway Colin.
Want to speak to someone in the morning and understand the process before I open my mouth and talk "cr*p" :-)
Dean
Hey Dean, that’s totally fine. Im not in any rush.
Hi Mr Vaughan, almost correct!!
Up Stream 448 (Kbps.)
Down Stream 4384 (Kbps.)
So with interleaving off, would I sync at a lower speed or am I barking up the wrong tree? :?
csogilvie
Interleaving off synchs you at a higher rate, I think, which can cause line instability etc.
Acutally - when you moved house did you move straight to MaxDSL?
Dean
Correct!
Moderators note by John (johnessex) full quote of preceding post removed as per the Link:rules
Yep, when i got back from the States everything was up and running.
So what’s the general feeling then guys, shall I leave interleaving on?
I am worried about my ping though. 48ms average on this BF2 server, pretty poor that.
C:\Documents and Settings\*****>ping 193.93.45.178
Pinging 193.93.45.178 with 32 bytes of data:
Reply from 193.93.45.178: bytes=32 time=53ms TTL=120
Reply from 193.93.45.178: bytes=32 time=35ms TTL=120
Reply from 193.93.45.178: bytes=32 time=52ms TTL=120
Ping statistics for 193.93.45.178:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 35ms, Maximum = 53ms, Average = 48ms
Tried pinging Jolt also:
C:\Documents and Settings\*****>ping www.jolt.co.uk
Pinging www.jolt.co.uk [82.133.85.65] with 32 bytes of dat
Reply from 82.133.85.65: bytes=32 time=51ms TTL=56
Reply from 82.133.85.65: bytes=32 time=49ms TTL=56
Reply from 82.133.85.65: bytes=32 time=36ms TTL=56
Ping statistics for 82.133.85.65:
Minimum = 36ms, Maximum = 51ms, Average = 46ms
Cry
interleaving on Max can add 20 -> 40ms to your normal non-interleaving ping times.
Mine went from 16->20ms to 50 -> 60ms.
