Broadband Fault Checker
cossey
What a pain in the ar$e!!
It's just too rigid not allowing for anything that doesn't fit into a neat 'category'.
Can I not just talk to someone about my problem? Do I HAVE to go through fault checker?
Evil Evil Evil Evil Evil
1 REPLY
Mand
When going through the fault checker there is a comments box at the end where you can add any information which doesn't fit into the standard question and answer format.
You can also give our support team a call, however if you wish to raise a fault they will need to ask similar questions as these are required by BT.
