Broadband Fault Checker
How longs that been there then ? I just noticed it when going to do a speedtest. It looks pretty good.
A few days Smiley
It's very good!
Best Wishes,
LiamM
I believe it went live mid-week. It does certainly look very impressive.
what exactly does it test for during initial tests?
I believe it only works if you try using it from your PlusNet connection..
LiamM
AFAIK it works from anywhere. The initial checks test to see if there are any PSTN reported faults on your line etc...
link?
Please?
Wheelie
Its in connection settings getitonbangagong
I tired it and get PSTN Check Initial checks have identified that a fault is being investigated on your telephone line
Not aware of any faults on my line I phoned Plusnet and was told there must be a fault at exchance and BT must be working on it Cry
I got that too :lol:
maybe it's a general fault.
I get this:
We have identified that BT are currently investigating a fault on your telephone line :?
maybe BT are investiating faults on everyone's lines, the fault being we've all been capable of getting 24Mb connections all along ....
sorry i've been varnishing, must be the fumes.
Well just so you know; mine showed all clear. So take heart those who BT are working on!
Thanks for the link, useful!
Just found it........ great addition :-)
Golferpete
Fault finder
Hi
I just found it to.should save some phone calls to CS
Pete.
