Broadband Bandwidth Usage Graphs
Here:
http://portal.plus.net/support/broadband/network/broadband_bandwidth_usage.shtml
Can anyone explain on the bottom graph the sharp dip in the total users online (red line) that jumps straight back up again a few minutes later? I have a problem where my connection drops around that time every nightHuh?
James
It appears to have just been a one off. It's definitely not something that happens every night.
Okeydokes - James while you are on, can you get someone to look at question 19998702?Huh
James
Does this always happen at the same time of day?
Generally yes - I get home from work and router shoes 0kbs and 0kbs as up and down sync and I reboot only to find around 9 or 10 o'clock pm I have to reboot to get a connection that works. I've replaced my router thinking that could have been the cause but the same issue has happened with the replacement and I am connecting using the test port of the master socket. Driving me daft!
Plusnet Staff
Plusnet Staff
I've sent it on to BT for you to take a look at, hopefully a remap of the target SNR and applying interleaving should fix this for you.
