Broadand??? No b in band!
Hi!
Has PlusNet realised yet that when the message box pops up to say "PlusNet Broadband is connected" --- what it actually says is "Broadand" with no b in band!
C'mon PlusNet! You can do better than that! Did'nt you watch the "Test the Nation" on the use of English?
I'll forgive you if it's altered shortly!
JonathanW
This sounds more like something on your particular connection, rather than on our side, as we don't have any popups that alert you to the connection being established.
Where do you see this message?
Surely it is your system that creates this message from a connection which you have created?
B in Broadband
Er, yup! If no-one else is getting it, then it must be just me. Sorry, folks! End of story, okay?
Smiley No worries. Understandable mistake.
Fixes: 69
Are you using a modem? I suspect you made a typo when initially creating your BB connection. Assuming you are using XP, go to Network Connections and you should see a dial up connection called 'Plusnet Broadand'. Simply right-click this and select 'rename'. You should then be able to correct the spelling.
Kind Regards,
Plusnet Products Team
Classic!! ^^ :lol:
Do you ever wish you could turn back time mjcaisey? Shockedops: Smiley
Don't feel too bad about it, we all have posts we wish we had never posted! Wink
What do you expect? After all usenet has been renamed dontusenet. And its not even a typo... Wink
:roll: Did you have to bring that to this thread? :|
Sorry... :lol:
hehehe .. classic post Wink
No B in broadand
Thank You, Bob Pullen!
Did exactly as you suggested and the spelling is now correct!
Apologies to all - can't believe it took me xx number of months I've been with PlusNet to notice it! So keen to get online, obviously!
Do I feel silly? Silly & sorry!
Goodnight from her Smiley
Re: No B in broadand
Please don't feel sorry! ......... Silly.... yer! Tongue You gave us something to smile about! Cheesy
And goodnight from me! Smiley
